01-06-2021 | #1 |
Starter Solenoid Connector
I am looking for a couple Starter Solenoid Connectors just in case anyone has a non-repairable Starter.
I have a couple of broken Starter Solenoid Connectors. The Solenoid Connector can be disconnecting from the copper connector with a solder iron as shown. The Solenoid Connector can then be tapped out using a flat screwdriver and hammer from inside. The connector shown in first photo below was removed incorrectly by prying on the outside breaking the plastic part inserted into the hole "so the tab that was soldered is not showing in first photo below".
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-06-2021 at 08:59 PM. |
01-06-2021 | #2 |
Re: Starter Solenoid Connector
Hey Cliff,
Can the plastic housing glued back together? There are some incredible adhesives these days. I have never dealt with these guys but looks like they carry extensive starter parts for all starters including nippon Denso. https://www.amscovf.com/NIPPONDENSO-...S_c_32853.html |
01-10-2021 | #3 | |
I did not find the connector however and the connectors were broken and the broken piece lost. I was hoping someone could find those connectors at a site such as you mention or.....know of a starter non salvageable from which parts can be removed |
