Old 12-22-2020   #1
Corvette95
Corvette95's Avatar
Default Is the exhaust stud in the head of any use after stock manifold replacement
So, I reinstalled both studs with Loctite 565 in the heads today in anticipation of bolting on the headers tomorrow. Is there any reason to reinstall the nut on the studs? I installed the studs until they were fairly tight (all the way to where the non threaded section started), I am afraid if I put the nuts back on the stud they may twist as I tighten them and break the thread seal loose and I don't want an oil leak. Thanks.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 12-22-2020   #2
Default Re: Is the exhaust stud in the head of any use after stock manifold replacement
No. The original purpose of the center stud was to hang the manifolds during assembly at BG.
