Old 12-07-2020   #1
Corvette95
Corvette95's Avatar
Default How much room do I have to shim the drivers motor mount for headers
How much room do I have to shim the drivers side motor mount for the OBX headers to clear the steering shaft? I am also coating and wrapping them in titanium wrap so I will likely have to dimple them too. What shim size (max thickness) can I use without engine touching hood? I know it is close already. Thanks.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 12-07-2020   #2
secondchance
Talking Re: How much room do I have to shim the drivers motor mount for headers
Of 5 ZR-1s worked on by Wazoo, none needed shimming. 4 were Stainless works and mine was OBX. Apart from shorter length to accommodate fake cats, OBX runners are almost exact duplicate of Stainless Works.
Old 12-07-2020   #3
Corvette95
Corvette95's Avatar
Default Re: How much room do I have to shim the drivers motor mount for headers
Thanks, I have read posts saying both yes and no, most requiring a dimple at least. I know mine are going to be thicker due to the coating and wrap.
Old 12-08-2020   #4
wfot
wfot's Avatar
check the health of the motor mounts... I hear they can deteriorate, this would drop the motor down some... worth a check if you are in there
wfot is offline   Reply With Quote
Old 12-08-2020   #5
Mr Blue
Mine only required dimpling #1 tube by the steering shaft. I used the Maximizer headers that are the same as OBX without the polished finish.
Good Luck
Mr Blue is offline   Reply With Quote
Old 12-08-2020   #6
Jagdpanzer
Jagdpanzer's Avatar
Keep in mind it's possable to push the engine over to the right a few mm if necessary before tightening the mounts down.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-08-2020   #7
Corvette95
Corvette95's Avatar
Thanks, would this hurt the driveline tolerence, I currently have the C-Beam off waiting on C-Beam plates from Bill B.
Old 12-08-2020   #8
If you have kids, there may be some silly putty or clay about. But a ball on the plenum & close the hood. Check the clay/putty & measure the thickness to determine hood clearance.
Old 12-08-2020   #9
Corvette95
Corvette95's Avatar
That's a really good idea, what do you think the highest spot would be..seems like the front of the throttle body and ECM. No kids, but I have some modeling clay!
Old 12-08-2020   #10
Jagdpanzer
Jagdpanzer's Avatar
Should be ok
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
