04-25-2007 | #1 |
ENGINE
I HAVE A 90 WITH 38,000 , I HAVE A MOTOR NOISE AT REV. WHEN LETTING OFF THROTTLE, SOUNDS LIKE BEARING NOISE?? OIL PRESSURE IS VERY GOOD, NOISE IS LOUDER IN MORNING, ANY IDEAS???/ HATE TO TEAR DOWN AND NOT FIND A PROBLEM, KEVIN
04-25-2007 | #2 |
Re: ENGINE
does the car make noise in neutral with the clutch out / you could be losing the flywheel?
04-25-2007 | #3 |
Re: ENGINE
WE CHECKED THE FLYWHEEL IT IS OK, REV AND BACK OFF, IT WILL MAKE NOISE MOST OF THE TIME, WHEN PULLING OUT MAKES NOISE UNDER LOAD, KEVIN
04-25-2007 | #4 |
Re: ENGINE
You should try to locate the noise, front, rt side, left side, center, deep, etc and use a rod (wood dowel rod abt 2' long) placed on the engine and to your ear. Is the noise rpm frequency, no particular frequency, multiples of rpm frequency? Describe the noise; rattle, knock (heavy or light), tinny, etc.
Check all the pullys & belt to see if it's a bearing (tensioner, AC clutch, PS pmp, water pmp) or pully. A timing light works pretty good. Very difficult to analyze like this.
04-25-2007 | #5 |
Re: ENGINE
where in pa are you from
04-26-2007 | #6 |
Re: ENGINE
I AM IN ALTOONA PA.
04-26-2007 | #7 |
Re: ENGINE
I had one of these weird noises under the car and almost tore the Z apart trying to find it only to discover it was a loose exhaust heat shield which really showed itself at 15-1800 RPM. Not saying this is what your problem is but sometimes little things can be the worst and lead to spending big money needlessly.
1991 ZR-1, Black, Black, # 541 |
04-26-2007 | #8 |
Re: ENGINE
I'm wondering about the catalytic convertor(s). Wasn't it the 90 model without the screen and catalyst could get back into the exhaust header? Point is, it could be in the catalytic convertor, hence the reason to try & isolate where it's coming from and the frequency.
Loose heat shields, as stated above, have ocurred several times, driving the owners nuts to find the source.
04-27-2007 | #9 |
Re: ENGINE
THANKS FOR THE POSTS, I WILL CHECK AND POST WHAT I FIND OUT, KEVIN
04-27-2007 | #10 |
Re: ENGINE
I've been trying to think of anyone around the area that you could take the car to and I can't think of anyone. Sorry
