Old 10-02-2020   #1
Mystic ZR-1
Mystic ZR-1's Avatar
Default Front FX3 shock actuator 1990
Anyone got one for sale?
The front actuators have a longer pigtail?
PM me if ya got one.
Thanks!
Old 10-02-2020   #2
BigJohn
BigJohn's Avatar
Default Re: Front FX3 shock actuator 1990
Thanks!
Can y?all have it rebuilt?
Old 10-02-2020   #3
ram_g
Zip and Eckler?s both carry new reproduction actuators. A bit pricey at $200 but they work fine.
ram_g is offline   Reply With Quote
Old 10-02-2020   #4
Mystic ZR-1
I've got an email into Mark Mirrock.
He should have several?
Old 10-03-2020   #5
secondchance
Concern is that plastic tends to get brittle with time. A few more bucks for brand new may be worth it. Just my 2 cents.
Old 10-03-2020   #6
Mystic ZR-1
Problem solved!
Nut on top of shock was loose allowing crown/cup to move around.
Tightened nut, cleaned actuator and electrical connectors with electrical contact cleaner and put back together. Cleared codes and went for a test drive. No codes returned and shocks appeared to respond to switch position.
Always use the KISS method before you buy "not needed" parts...
Many thanks to those who responded by PM and posts with parts availability and suggestions!
Old 10-03-2020   #7
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
You can always tie a piece of string to it and run it into the car by your seat.
A gentle tug is all that is needed.
Doug,
Glad to hear that you resolved it!!!!!!!!!!!!
Old 10-04-2020   #8
Mystic ZR-1
Marty
If I'd known, would have done that
and saved a lot of work. Next time I have a problem,
I'll contact you 1st....
