Old 09-16-2020   #1
Corvette95
Corvette95's Avatar
Default Help with coolant metal house routing
If anyone has their car handy, could you shoot me a picture of how the heater hose and overflow metal lines are routed and how they mount and mate at the center wheel well. I had them both off and can?t seem to get them to fall into place, ( not sure which is the inner or outer - seems the coolant lines mate directly to the wheel well and the overflow line attaches to the heater hose from the engine side) I don?t want to force them into a wrong position. Seems the overflow line mount to the coolant line, are they bolted from the inside or outside. Thanks IMG_6104.JPGIMG_6106.JPG
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 09-16-2020   #2
Default Re: Help with coolant metal house routing
Not mine, but best pic I have. Hope it helps...
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 09-16-2020   #3
Corvette95
Corvette95's Avatar
Thanks Paul. That did help!
Old 09-16-2020   #4
Subfixer
Subfixer's Avatar
In addition, there's a metal clip that holds the overflow hose to the frame rail near the overflow tank.
Don't forget to clip the hose in before you close the hood, otherwise it will get caught up in the headlight housing when you flip the headlights up.
Yup, happened to me. scratched up the headlight cover.....
2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
Old 09-16-2020   #5
Corvette95
Corvette95's Avatar
Thanks, haven?t even looked for the clip. I had to r/i the hose because I had the upper line mis routed. I will write a note for that clip in the morning!
