Old 08-29-2020   #1
Norwegianmopar
Norwegianmopar's Avatar
Default EGR tube leak
The tube is shot and needs to be replaced. Any tips on where to get a new?
It's a 94 ZR-1 with Watson headers and Corsa exhaust. received_839573393244796.jpg20200828_173703.jpg
Sent from my SM-G955F using ZR-1 Net Registry mobile app
Roy Martin
1994 ZR-1 #112 Admiral Blue/Black
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
1991 ZR-1 #400 White/Red (SOLD)
Dana 4:10
Powder coated engine
Haibeck performance chip
Borla exhaust
Norwegianmopar is offline   Reply With Quote
Old 08-29-2020   #2
Norwegianmopar
Default Re: EGR tube leak
Another question is: Do I need the EGR at all? My old 91 ZR-1 did not have it.
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 08-29-2020   #3
If you are not required to have it for emissions inspection, then eliminate it. Plug the hole in the exhaust and plenum.
Old 08-30-2020   #4
Norwegianmopar
Looks like quite a job removing the pipe completely, so can I leave it there (for now) if I disconnect it..? Just to avoid driving with the leak until I eventually get a new one (fear the emission tests might be troublesome?).
There will not be any codes to deal with if we do this?
Finally, where do I get new parts to fix it?
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
Old 08-30-2020   #5
tf95ZR1
tf95ZR1's Avatar
Hi NorwegianMopar!
Are you sure your EGR tube is "shot?"
I see the outer heat shield with crimped
solid inside tubing. It all looks secure.
Mark Haibeck taught me that the connector
is called an Oetiker clamp and uses a special
tool to crimp. Interesting to look up.
Removing your EGR system because
you don't need/want the smog option
is another issue.
Good luck!
PS: Looking at your pictures again I think
I see a crack in the outer (heat) shielding.
Is that what you are talking about?
Not a problem, or at most maybe apply
a wrap of heat resistant tape.
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
Old 08-31-2020   #6
Norwegianmopar
Originally Posted by tf95ZR1 View Post
Hi NorwegianMopar!
is another issue.
Good luck!
My mechanic said there are cracks in the tube upwards from the end we see in the pic and that it needs to be replaced. Quite a job it seems.
Marc Haibeck has the parts I need, so I guess it has to be done. NOX w/o EGR in my car will be twice the level of a 92 that doesn't have EGR if I remove it - bad when trying to pass the emission control...
Typical my luck just 500 miles or so after it had a full tune up and service at Haibeck's last summer...
Roy Martin
Dana 4:10
Aluminum flywheel
Corsa exhaust
Watson headers
Haibeck chip
470 HP/399 RWHP
Dana 4:10
Borla exhaust
