![]() Join Date: Jan 2005
Where is the control box located that controls the head for the A/C in a 94/95 model year. It is the unit that has the vacuum lines
![]() Join Date: Jul 2007
Above the accelerator pedal it is a black box
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
![]() Join Date: Aug 2012
https://www.youtube.com/watch?v=3jgvX967Q0o
Batee.com is the place to go for any repairs. They did an outstanding job on mine and turned it around in 2 days. Their videos are very helpful.
Thanks Guys
#5 | |
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-15-2020 at 09:13 PM. |
![]() Join Date: Feb 2011
#7 | |
Actually pretty easy 👍
Remove 7 (7mm hex heads) screws to drop hush panel (including one nut/keeper on threaded screw by firewall). Disconnect light and ALDL connector from hush panel. Remove 4 bolts from lower steel brace. Everything is then open and available including the several relays or if you want to bypass the Clutch Safety Switch 👍👍 Only takes 5 min for the removal above 👍 Post 292 - Locating Relays Above Drivers Side footwell Post 293 - Bypassing Clutch Safety Switch
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-16-2020 at 09:05 PM. |
