Old 07-29-2020   #1
S.hafsmo
S.hafsmo's Avatar
Default High Coast- / start up idle
I've always had periodic high idle (1500-1800 RPM) while coasting and just after start up. It did improve with the Haibeck chip, but it's still very much present. My throttle body has also been refurbished by Mark. Except of the above mentioned situations, it idles steady around 750 RPM.
Is this normal? Might it be caused by a slow/defective IAC?
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 07-29-2020   #2
Ccmano
Ccmano's Avatar
Default Re: High Coast- / start up idle
Normal, especially for 90'. It was an emissions thing.
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 07-29-2020   #3
S.hafsmo
S.hafsmo's Avatar
Well that's annoying. I was hoping something was broken.
Thanks, though.
- '90 ZR-1
Old 07-30-2020   #4
Thanks, though.
Agreed. Especially annoying should you stall the accidentally stall the motor in stop n go traffic.
Until you can stop and let the idle fall back to normal - about 3 seconds or so - idle will remain high on restart. (Takes some extra attention to technique to avoid it (accidentally stalling). Just a quirk of the 90s, it seems.)
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
