Old 07-24-2020   #1
pbzzz
Default Fuel pump replace questions
Original fuel pumps are shot. Have read about replacing . . but having the old one out I have questions - 1) The 2 pumps are molded together as a unit and are mounted on a spring loaded tube from which I see NO WAY to remove them . There is a square metal tab spot welded to the bottom of the tube making them non-removeable . 2) if I somehow solve this spring loaded tube problem, how do I convert to 2 individual fuel pumps ?
I am completely lost as how to do this fuel pump replacement . All help appreciated . . .
attached picture shows pen pointing to spot welded tab on bottom of spring loaded tube.
pbzzz is offline   Reply With Quote
Old 07-24-2020   #2
pbzzz
Default Re: Fuel pump replace questions
forgot to mention this is 1990 stock Zr-1
Old 07-24-2020   #3
pbzzz
feeling like a real dummy here . . . I see that the pumps slide down into a solid joined plastic case so I only have 1 question left . . . Does anybody know who to order the filter / socks from and proper p/n#s ? Thanks to all .
Old 07-24-2020   #4
G8nightman
G8nightman's Avatar
Last time i checked everything is on rockauto
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 07-24-2020   #5
ZuggZR1
ZuggZR1's Avatar
I got mine a year ago from 2 local Napa stores.
George Zugg
1990 DRM 500 ZR1
build#952
[SIGPIC][/SIGPIC]
ZuggZR1 is offline   Reply With Quote
Old 07-25-2020   #6
CamP
Cut the zip ties located on top of each pump and they will lift out of the plastic housing.
See my recent post "Fuel pumps" for info about parts.
CamP is offline   Reply With Quote
Old 07-27-2020   #7
Very pleases y'all found some diverse sources for parts. It is always a good thing to have some choices for parts, especially since so much stuff is made in China theeze dayz. But, FYI, case y'all are new here, Jerry, aka Jerry's Gaskets is a Registry sponsor, and long time supporter of our cars. Keeping our cars running would be a lot more "challenging" if not for Jerry Downey.
Old 07-27-2020   #8
Karl
Karl's Avatar
Yes the pumps come out from up top. You need to cut the zip ties. Also best to replace the plastic style clamps with metal. I prefer self clamping vs the screw types.
And you will install the pumps in the opposite position as you removed them.
Make sure the wire harness on both pumps is attached so you don't have to do the job twice 😂! Been there done that...
Besides that it is an easy job.
Old 07-28-2020   #9
Erik
Two questions.
First, exactly what kind of clamps do you have in mind?
Secondly, I don't understand how I would install the pumps in the opposite direction.
Thanks!
Erik is offline   Reply With Quote
Old 07-28-2020   #10
ZuggZR1
ZuggZR1's Avatar
I actually documented some of the steps when I did my fuel pumps last year: https://zuggszr1.com/gallery
George
George Zugg
1990 DRM 500 ZR1
build#952
[SIGPIC][/SIGPIC]
