Old 07-18-2020   #1
Jagdpanzer
Jagdpanzer's Avatar
Default Another Project complete - Under Hood Lamp Cutoff Switch
Finally got around to installing bright LED bulbs and under hood cutoff switch.
Rocker style cutoff switch spliced into the orange wire coming from the under hood lamp fuse.
LED lamps
Left LED lamp
Right original lamp
Both LED
Big difference!!
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-18-2020   #2
Default Re: Another Project complete - Under Hood Lamp Cutoff Switch
What LEDs did you go with? I have ZEVOs.. no switch though
Old 07-19-2020   #3
Prez1967
That looks great!
Prez1967 is offline   Reply With Quote
Old 07-19-2020   #4
Jagdpanzer
Jagdpanzer's Avatar
LUYED 2 X 570 Lumens Super Bright 3014 48-EX Chipsets 569 578 211-2 212-2 LED Bulbs Used... https://www.amazon.com/dp/B0177DD3E2...s_api_i_ZuffFb...
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-19-2020   #5
lfalzarano
Says it doesn?t fit ?90. How did you search for it?
Old 07-19-2020   #6
Those bulbs will fit a 1990..
Old 07-19-2020   #7
lfalzarano
Thanks Jeff!
Old 07-19-2020   #8
Jagdpanzer
Jagdpanzer's Avatar
Searched under 42 mm automotive dome lamp
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
