Old 07-15-2020   #1
tf95ZR1
tf95ZR1's Avatar
Arrow Punctuation Problems
Some of you may be experiencing punctuation issues with your posts.
The problem is coming from electronics using certain iOS platforms.
The fix is on YOUR end ("Smart Punctuation" issues).
Do your research and due diligence, as the ZR-1 Net Registry
takes no responsibility if your iPhone or computer self destructs.
Solution from VBulletin:
"This is happening on our development site as well. If you turn off
Smart Punctuation
on the ipad Settings --> General --> Keyboard -->
Smart Punctuation, the apostrophies work correctly "
"It is caused directly by the "curly quotes" used with the smart quotes
option in iOS and comes down to UTF-8 support. It will most likely need
programming to fix."
Computer nerd stuff beyond my pay grade.
Good Luck!
Ted Feder
Forum Admin
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
Old 07-15-2020   #2
Erik
Default Re: Punctuation Problems
You must have seen my posts.
Thanks for the heads up.
Erik is offline   Reply With Quote
Old 07-15-2020   #3
Mystic ZR-1
Mystic ZR-1's Avatar
"Mine too"
Turned it off
Let's see if it works?
Mystic ZR-1 is online now   Reply With Quote
Old 07-15-2020   #4
Mystic ZR-1
Looks like it did?
Thanks Ted
Old 07-15-2020   #5
BigJohn
BigJohn's Avatar
I kind of liked the question marks in the conjunctions
Old 07-15-2020   #6
A1990
A1990's Avatar
Conjunction junction what's your function...
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Chairman of the Board
ZR-1 Net Registry Treasurer
A1990 is offline   Reply With Quote
Old 07-15-2020   #7
Erik
Let's see how this works.
