![]() Join Date: Mar 2007
I have an issue with the fans turning on once the ignition switch is turned into the accessory position, as in supplying power, but the car is not running. I have reset the prom multiple times and even replaced the prom. disconnected the temp switch on the inj housing, and even trying jumpering the AC high pressure line switch
Thoughts, I think the only other potential issue is ECM?
![]() Join Date: Feb 2012
Is the engine warm?
No this is from the moment you turn on the switch, even when dead cold
I should probably mention its only the primary fan... and I did swap relays with same result
![]() Join Date: Jan 2006
Check if your A/C pressure switch is unplugged or bad. (on high side line with red upper body)
#6 | |
I jumpered the connector ..... didnt change anything, also does the car have to be running to turn it on due to the pressure switch.... this happens on mine in accessory mode
So Lee, with ignition ON but not running, do fans come on?
#9 |
If the connector is bad or unplugged the fans will run all the time. I am not sure if jumping it will work or if it is a resistance number it is looking for.
Corvette95 Registry and Forum (*************) 1989 C4 Conv Wht/Gry Auto Hardtop Top Flight SOLD 1995 C4 Coupe Purple/Blk 6 Speed 1989 C4 Conv Wht/Red Auto SOLD 1996 C4 Conv Black/Tan Auto SOLD 1994 C4 Coupe Wht/Blk SOLD 1995 C4 ZR-1 White/Gry #278 Dual Dunn Head SOLD 1986 C4 Coupe Black/Red 4+3 SOLD 1990 C4 ZR-1 Red/Red #0454 Last edited by Corvette95; 07-04-2020 at 01:04 PM. |
#10 | |
