Old 07-01-2020   #1
VikingTrad3r
VikingTrad3r's Avatar
Default falling on its face while decellerating when i lay the throttle on again approx 3000r
Hi Everyone. I've owned my zr1 for just over a year now and i've sold my other c4's off. Finally getting to enjoy some serious alone time with it. Intoxicated by the LT5.
ive got an issue here is the best description i can muster:
during deceleration, while passing down around 3000 rpm....if i begin to lay into the throttle again as it is passing through the 3000 rpm range....the car falls on its face, it doesn't die, it just feels like its not getting enough gas quick enough to accelerate...then it 'catches', bucks once or twice and then takes off.
i have the haibec chip and my secondaries are wired open.
the car pulls just fine up over 7000 rpm.
secondary fuel pump? it happens right at 2900-3300 rpm range....if i lay into the throttloe again as its dropping down through it.
due to it being very predictable and happening every single time i do that, i thought maybe a coil or something
VikingTrad3r
Calgary, Canada
1991 ZR1 # 888 - daily drive whenever possible
1991 ZR1 engine from unknown sn.
1990 Z51 zf6 being built into narrow body ZR1 racer
1987 z52 auto - sold
1986 'z31' 4+3 - sold
1985 Z51 auto - sold
VikingTrad3r is offline   Reply With Quote
Old 07-01-2020   #2
Ccmano
Ccmano's Avatar
Default Re: falling on its face while decellerating when i lay the throttle on again approx 3
Does it show any codes?
Did this happen immediately after putting in the chip and wiring the secondaries?
What is the static voltage at the throttle position sensor? Should be 0.54volts
What else has been done to the engine?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 07-01-2020   #3
VikingTrad3r
Hi Hans, thanks for replying . To be honest im not sure if it was occurring before or after the haibec/secondary wiring. I never noticed it before the chip install. But i also did the chip install pretty quickly after acquiring the car.
no other mods.
Will check tps for voltage at 0 and full and look for dead spots.
Will look for the schraeder for fuel pressure testing as well and will see whats happening during the bucking.
VikingTrad3r
Calgary, Canada
Old 07-01-2020   #4
Ccmano
Ccmano's Avatar
Other than the mods, have you done any other maintenance or parts replacement? Definitely check for codes.
H
Old 07-01-2020   #5
VikingTrad3r
i?ll pull out my paperclip but i know im not seeing the light flashing or staying on while driving.
VikingTrad3r
Calgary, Canada
Old 07-01-2020   #6
Same exact issue here: 1) Secondaries deleted.
Just spoke to Marc and there is no solid answer (yet) to the issue, EXCEPT possibly changing to a different set of O2 sensors (quicker to react).
I concur with his characterization of the problem:
1) secondaries deleted,
2) deceleration between ~ 1400-2000 rpm
3) stutter/lurch when back on throttle*
4) does not happen when decel below 1400 rpm (e.g., urban type driving)
The cure is a work in progress, according to Marc. Doesn't do it all the time, just a nuisance but seems more often when decelerating from high speed, w/ or w/o clutch engaged. (And, from personal experience, hot/humid days or at high (mountainous) altitudes it occurs more often)
Marc just gave me an O2 part to try (I'd rather not say in case it isn't a cure) and to get back to him if it affects this issue. (The issue is worse on the 93-95 MY cars, Marc says. However, my wife's 91 cammed ZR-1, also with SPTs deleted does NOT display the problem that I'm aware of.)
More on this after I get the new O2s.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 07-01-2020   #7
Ccmano
Ccmano's Avatar
I have my secondaries deleted, Dominic and I did the tune (mostly Dom) and I don?t have this issue. I do remember that during the tuning process we had a transient on throttle stumble we had to tune out. I believe it had to do with the Acceleration enrichment (AE) settings. Dom should be able to tell us.
H
Old 07-01-2020   #8
VikingTrad3r
Hi Paul and thank you for listing your symptoms.
Sound exactly the same except for mine is up near 3000 rpm.
it does feel like a fueling issue.
VikingTrad3r
Calgary, Canada
Old 07-02-2020   #9
VikingTrad3r
here is another thread discussing this issue
paul did you try installing new o2 sensors?
http://www.zr1.net/forum/showthread.php?t=23806&page=4
VikingTrad3r
Calgary, Canada
Old 07-02-2020   #10
In Full Power mode, the ECM enables the SPT to open at a proscribed TPS%. It opens the SPT first, then consecutively turns ON the Secondary Injectors. There is a delay there of about .3 sec to allow throttles to open in the stock calibration.
In decel mode, the Injector pulse is reduced significantly or shutoff completely (DFCO) leaning AF. When u hit the pedal again, there is a momentary delay before proper AF mixture gets to the cylinders. It typically requires a larger, quicker, pumpshot (AE), especially since the secondary runner is open, to overcome and is based on the change in MAP created by the accelerator movement.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
