Old 06-29-2020   #1
Corvette95
Corvette95's Avatar
Default 90 Low Oil Level indicator- disabled from factory?
Got the 90 running today with full fluids and fans. Ready for paint shop. I do not have dash or cluster in car. Checking coolant temp and oil etc via Tech1 . I do have a LOW OIL LEVEL indicator and Lamp Request On for the Low oil level on the Tech1 . Oil level and pressure and temp fine. As I am looking through the FSM, it says the low oil level is disabled from factory and the bulb removed from DIC. IS this correct and nothing to trouble check just because the Tech1 shows low oil level?
Thanks.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 06-29-2020   #2
Default Re: 90 Low Oil Level indicator- disabled from factory?
Oil Level Sensor is only present for 91~95 models
Old 06-29-2020   #3
conesare2seconds
^^^ this
Old 07-01-2020   #4
ghlkal
ghlkal's Avatar
I had the same reading on my 90, and there wasn't a bulb in the DIC for oil level, which I thought the PO may have removed.
So Thanks for the good info.
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
