Old 06-15-2020   #1
Zman
Default Front brakes both sides dragging
I took my 92 out today for a quick spin and when I got back I noticed a hot brake smell. Checked rears nice and cool, checked fronts and both very hot! Hot enough I couldn?t touch the Rims. I do know my clutch is starting to leak by. If I hold it to the floor in gear it gradually engages. Are these two systems connected? Please excuse my lack of mechanical aptitude. I did put the car in neutral while waiting for the brakes to cool and the car did roll easily. Any ideas?
Zman is offline   Reply With Quote
Old 06-15-2020   #2
Default Re: Front brakes both sides dragging
Just a guess as I went thru this a few years back. Front brake lines old and collapsing on the inside or bad Master cylinder. I did Master first and still had the issue went to all SS lines to the calipers problem solved.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 06-15-2020   #3
Zman
[QUOTE=We Gone;310380]Just a guess as I went thru this a few years back. Front brake lines old and collapsing on the inside or bad Master cylinder. I did Master first and still had the issue went to all SS lines to the calipers problem solved.[/QUOTE
Does the master cylinder control both the clutch and the brake hydraulics? I?m guessing this could be a laughable question.
Old 06-15-2020   #4
32valvZ
32valvZ's Avatar
[QUOTE=Zman;310381]
It does not. The Clutch master cylinder is mounted on the firewall left of the brake booster and just under the ECM. Its connected to a clutch slave cylinder by way of a hydraulic line, which is what turns the hydraulic energy into mechanical energy.
The brake master controls front and rear brakes. About 60% of the braking power is supplied to the front brakes, and 40% to the rears. Thats controlled by a proportioning valve.
I would agree that you can have bad rubber brake hoses and possibly a bad master cylinder and even still, calipers that could be in need of a rebuild or replaced with rebuilt units.
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 06-15-2020   #5
Zman
[QUOTE=32valvZ;310383]
Thanks for the information. Not failing from lack of use, more like too much use.
Thanks again.
Old 06-15-2020   #6
Zman
Is this work that can be done by ?Any? mechanic or is It suggested to take it to one of our specialists?
Old 06-15-2020   #7
Corvette95
Corvette95's Avatar
If you have a floor jack, jack up the fronts, one side at a time, motor OFF, emergency brake off, transmission out of gear, see if the wheel (each side one at a time) will spin freely by hand. If you are unsure about doing this own your own...TAKE IT TO A SHOP. Be careful and use proper precautions when jacking up any vehicle. (put a block in front and behind one of rear wheels to prevent rolling). This will tell you if the front brakes are dragging or locked up. Front brakes will most always be much hotter than rear on a street car.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 06-16-2020   #8
Guess I should have clarified a bit better I am referring to the brake master cylinder and original rubber lines to the calipers. As to your clutch issue most likely needs clutch and or slave cylinders replaced or rebuilt, if you do one I would do both. Many posts on the clutch parts here just do a search.
Steve
1990 Red/Red #1473
