06-15-2020 | #1 |
Ever wonder if a 30 year old spare works?
On my way home from a Sunday drive, stopped for gas and noticed my passenger rear tire was flat.....I was about an hour from home, I don't have AAA or a road side tire kit. So out comes the 30 year old dounut. Changed the tire and drove about 60 miles home. No issues at all. The spare was my hero of the night!
06-15-2020 | #2 |
Re: Ever wonder if a 30 year old spare works?
Happened to me once with the Quasar '93 in the late '90s. The TPS light came on and I used the spare and put the big tire in the tire bag. Boy did it look funny with a 13" wide tire on one side and a 4" wide one on the other! When I got to a gas station they discovered a 1/2" mending plate about 2" long embedded in the tire sideways; tire was toast. When I got the diagnosis I called my local tire dealer for the 315 Goodyear. When he called back a while later he said, "I have good news and bad news for you. The good news is there is one available in the country, in a warehouse in Indiana. The bad news is that it is the most expensive tire we sell." Oh well. One thing to note: The spare is supposed to have 60 psi of pressure, so it is always a good idea to check it occasionally if you still carry the spare. Just in case. Once I checked it and it was down to 25 psi.--Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 06-15-2020 at 10:51 AM. |
06-15-2020 | #3 |
Wow, you got lucky!! My original spare that I looked at after buying the car last November wouldn't hold air to save its life. Glad you made it home safely!
1967 Corvette convertible, L79, 4 speed, red / black / white top 1994 Corvette ZR-1, white / black NCRS North Central Chapter Judging Chairman |
06-15-2020 | #4 |
On my Polo '95 in 2016 its original spare tire still held 60 pis of air, at least for a pretty long time. I wonder if your spare's rim might be corroded. Ever have a tire shop dismount it to see? If the tire isn't cracked that might be the issue, as might a failed valve. Had a leaky valve on one of the regular tires my '95. While I would not want to drive very far on a 30 year old doughnut spare, it is still good to have in an emergency. Assuming you still have the spare tire carrier in place. --Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 06-15-2020 at 11:13 AM. |
06-15-2020 | #5 |
Thanks Bob, here is what I know. 1994 ZR-1, 21,500 miles when I bought it. It looks for all the world like the original spare tire and wheel combo. It has the correct markings. I didn't check the date code on the tire, but believe it to be original.
I took it out of the spare tire housing and it had decades worth of road dust on the tire. I put the tire in my garage sink to clean it after airing it up. It "spat" water at me around the circumference of the wheel (right on the bead) for roughly 35-45% of the circumference on one side, and about half that on the other side. In other words, it leaked like a sieve. I agree that having a spare tire is a good idea. Here is my glide path. Swap the front spring on the car (it is sitting too low has a base coupe front spring in the car right now). Swap the four road tires with recently acquired Goodyears. Have the car aligned. Address the spare. I guess I could have the shop address the spare tire right now. Nothing holding me back from that.
06-15-2020 | #6 |
OMG...
Put on the spare and screw up the tire crayon markings they put on at the factory 😀 What would NCRS say? Murphy?s law says you?ll have the flat tire at the worst possible time and location... Carry a can of tire goop, a tire plug kit with pliers to pull out the nail and a cheap 12v compressor. Of course none of this is any good if you rip a hole in the tire, refer to Murphy?sl law above... AAA card, just like your AMEX card, don?t leave home without it. |
06-15-2020 | #7 | |
I busted out the owners manual out of glove box and went step for step. Kind of neat how GM includes everything one needs, and where they stored things at. I also noticed, that the tire says " Must inflate to 60 PSI".....But our tire gauge that was original to the car, only goes to 48 PSI lol.... |
06-15-2020 | #8 | |
That's 30 years worth of patina |
06-15-2020 | #9 |
I have a cousin named Patina, but she is older than 30! Last edited by BigJohn; 06-15-2020 at 08:53 PM. |
06-17-2020 | #10 |
I have really had good luck and never used the spare in any of my Corvettes. This includes trips to Bowling Green with the cars. My 96 was a daily driver for at least 3 years. I removed my spare and cleaned it up with car wash preserving the markings and installed it back just the way it was. I took detailed picks of it when I removed it so I could reinstall the jack just the way it was placed at the factory. The Michelin PS'2 I purchased from Tire Rack actually come with a road hazard policy. The T155/70D17 is still available as it is used on new Toyotas and Lincolns.
I worked for an independent tire dealer from late 82 until 1990. I saw some crazy stuff pulled from tires drivers ran over. Things like 2x4's, large portions of lawn mower blades, large bolts that went in head first, sections of glass bottles, and just about anything you can think of. I prefer to patch a tire when it's in the center section of the tread. We used a cone shaped plug installed with a gun. Although I have seen the plugs cut by the tires steal belts over time. Also with a puncture that breaks the tires steal belts a separation may develop. When you strike a curb with the side wall a bubble or bulge may develop. This is caused by the inside layer of the tire breaking. We call that an impact abrasion which voids the warranty as does any puncture. I highly recommend getting a road hazard policy especially for tires that cost a couple hundred dollars.
91 Turquoise Metallic Haibeck 525 #0134 |
