![]() Join Date: Aug 2004
I want to get a few new gaskets for when I do oil changes. My first 91 ZR1 I swear the plug looked different and used the copper metal gasket. It was serial 0534. My current Z also a 91 has the metal and rubber gasket. It's number 0134. I am looking on Rock Auto and they have several different types. The cooper gasket, the metal and rubber gasket, and a fiber gasket. Which one should I use? Should I stick with the metal and rubber unit or get the fiber unit? It's a pain getting the plug off with the old compressed gasket. Any thoughts?
Fiber #DORMAN 097029 Metal/Rubber # DORMAN 097035 There is also a composite # MAHLE 2051
91 Turquoise Metallic Haibeck 525 #0134 |
![]() Join Date: Sep 2016
I use the metal and rubber because it does not fall off when I drop it in the drain pan.
![]() Join Date: Oct 2017
Jerry's will have everything you need.
He supports the Registry so I think we should support him. ![]()
Kenny 1990 #442 ![]() |
![]() Join Date: Jan 2010
Any seal that fits should work, unless your concerned about NCRS.
I like the metal with captured rubber o-ring type... |
![]() Join Date: Nov 2011
Jerry's
