06-04-2020 | #1 |
WTB: Corsa H-Pipe
Looking for a Corsa H-Pipe and resonator assembly.
Rich
06-04-2020 | #2 |
Re: WTB: Corsa H-Pipe
why just the resonator/H pipe?
06-04-2020 | #3 |
I had it on the lift over the weekend and found that the welds around both pipes at the front are cracked almost all the way around. It's like the resonator is breaking away from the two pipes. I was hoping someone that converted to and X pipe had one laying around. If I can't find one, I may be putting on a new system or upgrading the 3" and install those power effects mufflers.
Rich
06-05-2020 | #4 | |
06-05-2020 | #5 |
Yeah, I'm just not sure if you can get into that area to weld or not and you probably can't get into the space to clean it up (prep metal) to weld. I'll shoot some pictures, you'll see what I mean.
06-05-2020 | #6 |
Sounds like a good reason for a informal get together this weekend!
06-05-2020 | #7 | |
Rich
06-05-2020 | #8 |
Perfect, having withdrawls here
06-05-2020 | #9 |
So you thinking Sat....Sun? I can do either, not much going on here.
06-05-2020 | #10 |
Check with the brothers, I am open and it looks to be mostly dry both days
