Old 06-01-2020   #1
BigDave
Default FS 93 ZR1 Drive line & Rear Suspension Parts
I have a 93 Anniversary Ruby Red ZR1 that had 6800 miles when damaged which I decided to part out. The car has been garaged for the last 15-20 years. This post is for Drive line & Rear Suspension parts. If you need an item not listed please ask. Many parts remaining. All prices are plus shipping.
Rear Pumpkin Model 44 with 4:10 gears and Bat-wing - $900 (pickup only)
Drive Shaft - $100
Half Shafts (Each) - $60
Right Rear Suspension Knuckle Assembly with Spindle, Wheel Hub and Anti-lock Brake Tooth Ring with pickup - $195
Left Rear Suspension Knuckle Assembly with Spindle, Wheel Hub and Anti-lock Brake Tooth Ring with pickup - $195
Spindle Rods (Pair) - SOLD
Wheel Spindle (Upper & Lower Control Rods (2 Pair) - SOLD
BigDave is offline   Reply With Quote
Old 06-02-2020   #2
RICKYRJ1
RICKYRJ1's Avatar
Default Re: FS 93 ZR1 Drive line & Rear Suspension Parts
I'll take the upper and lower control rods & the spindle rods. lmk how much for shipping to NJ 07724
Old 06-02-2020   #3
BigDave
PM Sent
Old 06-07-2020   #4
carman49
Did the car have any noise from the differential when it was on the road?
carman49 is offline   Reply With Quote
Old 06-07-2020   #5
BigDave
I purchased the car after it was damaged. The car was on the track and hit the wall in the front.
