Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 NCRS for ZR-1s
Old 05-24-2020   #1
911ZR1
Default License plate screws
I have a 91 ZR-1 that has only two screws to hold the plate. Is this standard or should there be four? Is there a PN for the original ones? Just curious and figured this would be the place to find out!
Ivey
911ZR1 is offline   Reply With Quote
Old 05-24-2020   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: License plate screws
Should be 4 black Torx head screws with small washers.
They can be hard to find.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-24-2020   #3
Jagdpanzer
Jagdpanzer's Avatar
Corvette Central shows to have them in stock
https://www.corvettecentral.com/c4-8...c4%26count%3d9
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-24-2020   #4
911ZR1
Thanks! Not what I have on there presently.
Old 05-25-2020   #5
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Phil's two posts are 100% correct!
Marty
Old 05-26-2020   #6
Joelbbvette
Joelbbvette's Avatar
Now if the holes in the bumper are too large for the correct screws, you can take a plastic wall anchor (Grey or white is close to bumper color) and cut the flange and bottom off. Glue it in and use it as a sleeve. Don't ask me how I know this works. ;-)
Joel
Joel
Tampa/Rockledge, FL
Present Collection
1969 350/300 AC Convertible
1972 454 Coupe 2nd Owner
1988 KOH EX5006 - ZR-1 Prototype
1990 ZR-1 #277 NCRS Dave McLellan Award 2019
1994 Copper Convertible NCRS Dave Hill Award 2012
2001 Z06 122k miles
Joelbbvette is offline   Reply With Quote
Old 05-26-2020   #7
mpiecyk
Corvette Central states 91-96, shouldn't it be 90-96?
mpiecyk is offline   Reply With Quote
Old 06-11-2020   #8
Joelbbvette
I use the same ones on my 90 that received a McClellan Mark of Excellence without a deduction for them. I did not get them from Corvette Central though
Screw Head Dia 0.305"
Washer Dia 0.662"
T15 (from memory)
Joel
Tampa/Rockledge, FL
Present Collection
2001 Z06 122k miles
Old 09-10-2021   #9
Atari_Prime
Hi Phil,
These are the screws that hold the license plate itself in place, correct? Are there separate screws for the frame or does that basically fall off when you take the plate off?
Atari_Prime is offline   Reply With Quote
Old 09-10-2021   #10
DRM500RUBYZR-1
Plate and Frame use the same four screws, i.e. they go through both and go into the metal inserts on the bumper cover.
Marty
