Old 04-16-2007   #1
Hammer
Hammer's Avatar
Talking Rear Lowering and Antifreeze
OK, for those of you who have lowered just the rear with the bolts, have you noticed or had any handling problems at speed or otherwise? I will be seeing 150+ at the West Gathering this year and don't want to do anything that will jepordize the handling.
I am replacing cooling system parts (radiator, hoses, thermostat, antifreeze) in a couple of weekends and am planning on using the Zerex Original Green or G-05. Both meet or exceed the 1825M spec for our cars. Anybody had any problems with this antifreeze?
Thanks to all who may respond.
Old 04-16-2007   #2
zr-1assassin
zr-1assassin's Avatar
Default Re: Rear Lowering and Antifreeze
i'm getting ready to lower the azz about 1 1/2'' this week with the longer bolts. i will let you know how it feels afterwards
zr-1assassin is offline   Reply With Quote
Old 04-16-2007   #3
Hammer
Hammer's Avatar
Talking Re: Rear Lowering and Antifreeze
Outstanding, I will look forward to hearing about it. Also, if you can post what drop you actually got and what bolts you used.
Thanks
Old 04-17-2007   #4
Jeffvette
John, you need to keep a rake on the car. You make the rear even or lower with the front you will have high end stability.
Old 04-17-2007   #5
carter200
carter200's Avatar
Make sure to use distilled water not tap water
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 04-17-2007   #6
Hammer
Hammer's Avatar
Thanks to all. Good advice for sure.
Old 04-17-2007   #7
I may be out in left field on this but did you read the label and find the active chemical in the coolant you are going to use?
Sorry to butt in John. Some of the stuff that "meets or exceeds" does not use the same corrosion inhibitors as the original silicated 1825-M GM coolant. Most of all the newer coolants use an organic acid derived corrosion inhibitor as opposed to using a silicated something-or-other chemical. The key word is "silicated" or "silicates" that makes the coolant not eat the head gaskets...eventually. You can read the label and if it isn't listed at all or if it isn't listed in the MSDS label then that product is not using "silicates".
Old 04-17-2007   #8
jonszr1
jonszr1's Avatar
could you expand more on the contents of the anti freeze . by that i am asking what is the no no chemical to look for i am useing a green napa generic that says 1825 gm spec . but would like to know for sure as i have allready have one car thats popped a head gasket. but that one died before i could fix (80ft ) popolar tree center punched it atotal total a zr1 pancake. but could use any knowledge one has to choose the right stuff . my dealer is 1-100miles away and 2- wont order unless i by 10 cs so i am limited to what i can get . maybe someone that has thye knowledge of this stuff can start a list of the stuff thats ok . thanx
Old 04-17-2007   #9
UKZR1
UKZR1's Avatar
http://en.wikipedia.org/wiki/Antifreeze
http://www.consumeraffairs.com/news0...m_dexcool.html
I find most antifreeze labels give very little infromation as to whats inside. Working on the assumption that the more modern OAT stuff tends to be longer life, usually the labels claim 5 years, I buy the 2 year stuff (green/blue in colour) . The long life antifreeze is usually red/pink
Red/red 90 #1281 (UK)
Marc Haibeck 368
B&B, Brembos
DRM suspension
Known as 'Gixer' on corvettechat.co.uk
www.corvetteclips.co.uk
UKZR1 is offline   Reply With Quote
