![]() Join Date: Aug 2015
Just sharing a little info..
Owner filled up his 1990 ZR-1 with ethanol free fuel and drove the car home. Ran great. Went out to move it the following morning and it would not start. It would crank, just not start. Came in and I could get it to fire, but barely. I could hear the fuel pumps prime with key on. Checked fuel pressure, only 4 psi.. pulled and replaced fuel filter.. no change. Patched harness to switch to secondary fuel pump.. 5 psi at key on. Car would start, run about 3 seconds and die... no fuel from either pump.. New pump and sending unit assembly was in the car.. when I pulled the pump assembly, the hose from the Y to the fuel feed line fell off.. remember, brand new assembly in the car.. fuel pressure eventually blew the hose off the hard line.. The plastic hose clamp was positioned below the nipple! Replaced it with a stainless steel hose clamp.. fired right up.. So, don't forget to closely examine all hose connections, even with a brand new unit..20200514_094106.jpg20200514_094118.jpg Sent from my SM-G950U using ZR-1 Net Registry mobile app |
![]() Join Date: Jun 2006
Nice catch Steve. Yup, never assume because you put a new part into a car that all is well, should a related issue arise.
H ![]()
#3 | |
![]() ![]() Join Date: Nov 2007
![]() Join Date: Apr 2007
What the editor at the old Chicago News Bureau always told young reporters: "If your mother tells you she loves you, check it out". --Bob
How/Where did you get a NEW sending unit? I been looking for a long time for a new one...
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
#6 | |
I modified a standard LT-1/ LT-4 unit on a '96 Procharged build. Went with high flow TI Walbro 285 (470 lph). Since our LT-5 runs on one pump until WOT demands kick on the second pump, I'm wondering if this setup would work for the ZR-1.. LT-1/ LT-4 fuel pump/sending unit assemblies are readily available..23285.jpg23411.jpg23490.jpg Sent from my SM-G950U using ZR-1 Net Registry mobile app |
![]() Join Date: Nov 2010
Marc has an article in the latest Heart of the Beast about converting to a single pump (page 14, Issue 56).
Evan
2023 70th C8 HTC, 94 Admiral Blue ZR-1 SOLD - 2012 Carlisle Blue Metallic ZR1 - 800HP SOLD - Steel Blue 91 391cid ZR-1 #391 SOLD - Black 91 ZR-1 |
He used a Walbro pump available from Summit Racing as PN VPN-GCA758-2.
Evan
#9 | |
I definitely think this is an option! The 285 delivers more than enough for the LT-5.[emoji106] Sent from my SM-G950U using ZR-1 Net Registry mobile app |
