04-16-2007 | #1 |
Quarter Mile Shift RPM
What RPM's do you shift at for best 1/4 mile times? I have shifted at about 6500 in the past and am curious if 6000 might give a better time. I am going this weekend and thought I would throw this out fot the H of it.
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
04-16-2007 | #2 |
Re: Quarter Mile Shift RPM
Right before it hits the limiter. The car doesn't drop power much even stock, so it's making more power at the limit than it will wherever the revs drop to after the shift.
04-16-2007 | #3 |
That's about what I been doing. Like I said, thought I would throw this out and see.
Thanks for the reply.
04-16-2007 | #4 | |
04-17-2007 | #5 | |
04-17-2007 | #6 |
run a dyno, see on the power curve where the power starts to "tail off"
if you shift way past the peak, as jeff mentioned, the car will slow down. on the stock cars often the power peak is around 6300, so shifting at 7k is going to make the car run slower. rear gears have alot to do with shift points too. with the stock gears you are pulling 3rd through the traps.
04-17-2007 | #7 |
I do pull third at about 6500 through the traps. I will post more after this weekend. Thanks for the inputs fellas.
04-17-2007 | #8 |
when the car is geared properly,you should be able to shift at peak horsepower,and the engine should come down close to its maximum torque in the next gear.
bj 91/1735 |
04-17-2007 | #9 | |
Still, on the 1-2 shift (at 7,000 in 1st) I think the revs will drop to ~4,700 rpm. So as long as it doesn't drop that bad I'd still think you are better off running it to the limiter.
04-17-2007 | #10 |
Most stock cars at a 7K shift are back down to around 300 hp. and when you shift you are dropping the car back on the wrong spot of the power curve. You want to be hitting the curve where you are making the most power.
