Old 04-28-2020   #1
Jones7605
Default Rear main puking oil?
Wouldn’t you know it. I’ve had the car all of three days. I’ve noticed if I run the car fairly hard I’m seeing oil on my drive way. Looks like the rear main area. Normal driving and nothing shows. Any ideas? 2011 ZR1.
Picture for attention it’s not that big.
File Type: jpeg D0EA4630-2359-4DCB-813C-E96CC7EDB3E5.jpeg (39.1 KB, 53 views)
Jones7605 is offline   Reply With Quote
Old 04-29-2020   #2
32valvesftw
Default Re: Rear main puking oil?
Are you sure its not coming from up above and tracking down? There some oil leak areas like one of the header bolts that goes into an oil gallery, or the back of a cam cover. When I got mine I had a similar leak, and retorquing the oil pan bolts cured it for the past few years. The tech solutions part of this forum discusses most of the common oil leak areas. There is also Crossed Flags Performance in Magnolia/Tomball, Steve and his crew can fix you up in any case.
Old 04-29-2020   #3
Hib Halverson
My '19 had a defective rear main seal which was replaced under warranty.
If the rear main is bad, there will be oil weeping from the part line between the clutch housing and the block.
It's unusual for one-piece rear seals to leak, but it happens.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 04-29-2020   #4
Jagdpanzer
Jagdpanzer's Avatar
Reminds me of my old high school buddy’s 650 Triumph Bonneville.
He claimed it was just marking its territory.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-29-2020   #5
Jagdpanzer
Jagdpanzer's Avatar
Probably sometime leaking up in the valley making it way down the drain tube.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-29-2020   #6
Jagdpanzer
Jagdpanzer's Avatar
I’m with Hib. Unusual to see one piece rear main seal leak that bad.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-29-2020   #7
billschroeder5842
billschroeder5842's Avatar
That's my guess. I had a leak (not that bad) coming from the drain tube behind the oil pan. I took off the plenum and retighten the PCV crankcase baffle.
No issues since
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 04-30-2020   #8
tccrab
tccrab's Avatar
I think he's got the wrong forum, the airdam on the pic looks to be a C6 not a C4.
His signature might be a clue too.....
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 04-30-2020   #9
'Crabs
and..... his post says 2011 ZR1
Old 04-30-2020   #10
Ccmano
Ccmano's Avatar
All ZR1s are welcome here. I’m thinking maybe we should establish separate C6 and C7 ZR1 sections here on the forum. Thoughts?
H
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
