Old 03-26-2020   #1
Default Any new tips on passing smog test?
Last time I got a smog check it was pretty close to the max Nox level even though the cars only got 25,000 miles. Other than a K&N air filter and open housing it’s bone stock. I’ve got a little help from our friend Mr. H,any other tips I should look into,stock air box or open housing,low power mode at the valet switch? I’m thinking about running e85 just to be on the safe side. Thanks for any help here.
Old 03-26-2020   #2
tomcat
tomcat's Avatar
Default Re: Any new tips on passing smog test?
Hello,
To smog my ZR1, I drove on the freeway in 4th gear for a couple miles. Then I got off freeway and drove it 3 gear to the Smog station and she passed each time. In the stste of Washington.
Manfred E...
91 #906
tomcat is offline   Reply With Quote
Old 03-26-2020   #3
Ccmano
I wouldn’t change anything of your setup. Valet mode only, remove the key for the test itself. Get the cats good and hot immediately before you take it in by running it hard for half an hour or so. A fresh oil change can help with hydro carbon readings. These cars sit so much, getting started and stopped constantly without much driving. The cats get loaded up and need to be blown out occasionally. Beyond that hope for the best. Not sure about the E85.
H
Old 03-27-2020   #4
viper107
viper107's Avatar
run some seafoam through it with a quarter tank of gas, a dirty combustion chamber isnt helping, then run some super in it, then do what the rest say- maybe some octain booster also, hot flashes to heat up converters
viper107 is offline   Reply With Quote
Old 03-27-2020   #5
Jagdpanzer
Jagdpanzer's Avatar
I’ve had good results cleaning out combustion chamber deposits with running a tank of gas through mixed with Chevron Techron Concentrate Plus Fuel System Cleaner.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-27-2020   #6
find a state without smog Nazis and move there
Old 03-27-2020   #7
Ccmano
Given the political nature of that states with the worst emissions laws, it’s probably more appropriate to call them commissar’s than Nazi’s. But then Nazi’s were socialists too...
H
Old 03-28-2020   #8
lfalzarano
I agree with Jeff! Move!!!
Old 03-28-2020   #9
gapl1953
Don't use E85 it will only mess a lot of things up. These cars were not designed to run E85 and the components are not compatible to it.
gapl1953 is offline   Reply With Quote
Old 03-29-2020   #10
Corvettes White
Jeff I need the money, and my kids are here. And I know of no place in the world with the weather.
George.
Corvettes White is offline   Reply With Quote
