Old 03-25-2020   #1
billschroeder5842
billschroeder5842's Avatar
Default Squeaky sway bar bushings?
I'm getting a front end squeak as I go over some rough road and drive through my neighborhood. If I "bounce the car" I can replicate it. The front suspension is quiet when cold and gets louder after the car has been driven and the temperature outside heats up -- today was 91 in DFW.
My guess is that my bushings need attention. I want to swap them out with new ones and lube up the end links. Hopefully that will do the trick.
I'm double checking that our front sway bars require 30mm bushings? Any thing else I need to lube up or inspect as long as I'm crawling around under the car?
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 03-25-2020   #2
32valvZ
32valvZ's Avatar
Default Re: Squeaky sway bar bushings?
I thought the front was 26mm and the rear was 24mm
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
Old 03-25-2020   #3
billschroeder5842
Oh jeez.... this is why I'm asking.
Bill Schroeder
Texas Proud!
Old 03-25-2020   #4
32valvZ
32valvZ's Avatar
This has some info on it...... Looks like 26/26 for a 91... my 90 is 26/24
[B]1990 #2815[/B]
Haibeck Chip
FIC Injectors
Watson LT Headers
[B]SOLD[/B]
Old 03-26-2020   #5
If they are rubber, believe it or not, plain ol WD-40 is what we used in the shop. It pennitrates (creeps) between steel and rubber. Simple, cheap, & works great!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 03-26-2020   #6
billschroeder5842
Thanks Paul- I'll give that a try. Funny, as the car cools, it gets quieter.
Bill Schroeder
Texas Proud!
