![]() Join Date: Sep 2010
Installed LEDs in our friends 93.
Wife's 91 stock vs his 93 with LEDs |
![]() Join Date: Nov 2007
Did you ground the fog lite relay or use the LOAD RESISTOR method or...?
#4 | |
Anyway... LED headlights make a night and day difference! |
![]() Join Date: Jul 2007
I have LED headlights and LED Fog Lights. i added one relay and they all work like stock.
Relay was added prior to the LED conversion and still worked like stock
#6 | ||
I reinstalled a new relay and went with the 168 bulb method instead. |
IMHO this is a better way
One added relay: Cut Lt Grn ON OEM Fog Light Relay Power side of Lt Grn to Pin 86 of New Relay Pin 85 and Pin 30 of New Relay to Ground (New Wire) fog light side of LT Grn to 87a of New Relay. I found the Same style OEM relay on a harness and cut a length of wire with the relay socket.. I removed the terminal from the OEM relay and moved it to the new relay. Put this new relay right next to the OEM one in the dash.. works great
#8 | |
I decided to do this one as simple as possible for a friend of ours that doesn't do very much on his own cars. (headlight removal vs. under dash hush panel) I even bagged a new 168 bulb with instructions and placed it in the console. |
#9 |
![]() Join Date: Jan 2020
What LEDs are recommended for a 90?
#10 |
which bulb are you replacing?
