Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 NCRS for ZR-1s
Old 01-14-2020   #1
Jetjock
Jetjock's Avatar
Default Cleaning original wheels
I have the original set of wheels for my 93 ZR-1. I would like to clean them but I tried high pressure wash on the inside of the wheels but met with limited success. What has everyone done to clean up their wheels?
Roy L. Carman
If I feel the need for speed,
I just think about flying the B-777.
1989 Dk Blue Coupe lost in divorce
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
1993 Ruby Red 40th Anniversary ZR-1 #334
1995 Black ZR-1 taken by ex-wife
2002 Pewter Coupe no idea where it is
2003 50th Anniversary Corvette #No idea what number SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Jetjock is offline   Reply With Quote
Old 01-14-2020   #2
mpiecyk
Default Re: Cleaning original wheels
Hey Roy, This recipe I'm passing on to you is for the inside of the wheel ONLY!
I use Mothers Wheel & Tire cleaner its a strong detergent that works very well, after a minute of Mothers W/T soaking I use the 3M Ultra Fine (Gray) in color scouring pad, elbow grease is required.
Do this twice a year and you will maintain that factory finish.
mpiecyk is offline   Reply With Quote
Old 01-14-2020   #3
Jetjock
Jetjock's Avatar
Cool. Thank you. I have three sets of wheels to do so that will keep me busy.
Roy
Roy L. Carman
NCM Lifetime #1468
Old 01-15-2020   #4
mpiecyk
Roy, Try to purchase Mothers Wheel & Tire cleaner by the gallon rather than the 28oz spray bottle that most auto supply stores have, if I remember correctly I paid $25.00 per gallon @ Carlisle (2) years ago.
Old 01-15-2020   #5
Jetjock
Jetjock's Avatar
Yeah, that makes sense I will be doing three sets of ZR-1 wheels. What do you guys do for the painted surface? I have a 92 and a 93 Z’s. I believe that the 93 wheels are painted but the 92 wheels seem polished.
Roy
Roy L. Carman
NCM Lifetime #1468
Old 01-16-2020   #6
mpiecyk
Dawn dish soap for the painted and polished wheels.
Old 01-16-2020   #7
Joelbbvette
Joelbbvette's Avatar
Factory polished is still clear coated so treat them like painted. Dawn or Ivory dishwashing soap. I have also used Simple Green on the inside of the wheels cut with water starting at 20% S.G. and rest water. You can always increase the strength.
Joel
Joel
Tampa/Rockledge, FL
Present Collection
1969 350/300 AC Convertible
1972 454 Coupe 2nd Owner
1988 KOH EX5006 - ZR-1 Prototype
1990 ZR-1 #277 NCRS Dave McLellan Award 2019
1994 Copper Convertible NCRS Dave Hill Award 2012
2001 Z06 122k miles
Joelbbvette is offline   Reply With Quote
Old 01-16-2020   #8
Mystic ZR-1
Mystic ZR-1's Avatar
Simple Green full strength! Won’t hurt anything and cleans pretty good too.
You can even soak your dentures in the stuff! (Rinse ‘em off before you slap ‘em back in your mouth though..)
Buy it by the gallon at Home Depot or Walmart. I wouldn’t use it for car wash though, removes the wax...
Old 01-18-2020   #9
The 92 wheel is painted and the 93 wheel is brushed with a clear coat. Once you get the wheel clean try sealing the surface with a ceramic coating,that would keep the brake dust from sticking to the surface.
Old 01-18-2020   #10
Jetjock
Jetjock's Avatar
Thanks for the suggestions. I fo have a problem with my 92 wheels. It looks like some rust or something is under the clear coat. I was told that to fix that you would have to remove the clear coat and brush out the rust. Any ideas on that?
Roy
Roy L. Carman
NCM Lifetime #1468
