![]() Join Date: Oct 2019
Hi
I have a 1991ZR-1 I am trying to change Bose relay (relay that send 12V to each speaker AMP) ![]() Thank You Last edited by Stratos; 11-23-2019 at 11:03 PM. |
![]() Join Date: Aug 2006
If you are referring to CDM, yes. Passenger side.
If you’re talking about the CDM controller once you get the bush panel off. Take out the pass seat,get on your back,look up into the hole where it resides then relieze what a total pain in the a$$ the jobs going to be and have somebody else do it! I work on my own cars and this was one of the biggest pain in the a$$ I’ve ever done.
![]() Join Date: Nov 2016
Mine took over four hours with two weeks of recovery time for contorting my back.
Worst project I ever did on the car.
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker [SIGPIC][/SIGPIC] |
Post 139 - Bose Speaker Amps and CDM Replace
Thank You for the quick response actually relay that send 12V to each speaker AMP trying to change
![]() Join Date: Aug 2010
Left hand lower trim pad
Driver's knee bolster relay & wiring cable located at the lower right side of the I/P carrier push relay & cable away from carrier & pull down from retainer. |
