Old 11-10-2019   #1
secondchance
Default Air Filter Lid
Sort of been boring lately. So, I ordered a open filter lid from Eckler's only to find out it was a flimsy, cheap looking ABS plastic version - returned it of course!
Instead, I ordered a used OEM piece, chopped it up and painted it.
Ready to be installed.
https://flic.kr/p/2hHNrgT
Left over pieces.
https://flic.kr/p/2hHPx1T
Old 11-10-2019   #2
lfalzarano
Default Re: Air Filter Lid
You butcher!
Check the plastic air filter housing that connects to the coupler. I’ve had several seams along the sides split open allow dirt and crap to bypass the filter. Path of least resistance!
Old 11-10-2019   #3
secondchance
Thanks for the tip! I will check for sure.
While playing with it, I was pondering on mounting the filter on the flip side of the air box, cut a rectangular hole on the radiator shroud apron and drop in the assembly. This will allow the filter housing to suck the air when it enters the radiator intake area above the front air dam.
What do you think?
Old 11-11-2019   #4
lfalzarano
My thoughts are if that was a good idea, then GM would have designed it that way to add performance. Located with the radiator and oil cooler, the filter would be subject to road debris. On top of the radiator shroud, it is protected by that plastic deflector in the nose. Just my opinion.
Old 11-11-2019   #5
I would think a flipped filter could be a water issue.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 11-11-2019   #6
aafc
aafc's Avatar
If you would like to help reduce intake air temp place a piece of Reflectix
( bubble warp ) between the air box and radiator shroud. Cut the piece a little smaller then the air box so you wont see it. It will help reduce radiant heat transfer to the air box.Take car for a ride and then check temp with a infrared thermometer at the radiator shroud, then check temp on the air box. You should see about a 15+ deg temp drop.
http://www.zr1.net/forum/picture.php...pictureid=3967
1990 white/black #2546
one of a few 4l8OE eq ZR-1's
aafc is offline   Reply With Quote
Old 11-11-2019   #7
lfalzarano
Good tip!
Old 11-11-2019   #8
oldpro
I have a reverse air filter that was made before I got the car it seems to help a little a the strip . You want to make sure the filter is sealed well though
oldpro is offline   Reply With Quote
Old 11-11-2019   #9
lfalzarano
Good read on the intake.
Increasing intake air flow on a LT5
https://r.tapatalk.com/shareLink?url...2&share_type=t
