Old 11-05-2019   #1
grahambehan
Default LT5 valve guide failures
Found on a recent teardown
Graham
grahambehan is offline   Reply With Quote
Old 11-05-2019   #2
billschroeder5842
billschroeder5842's Avatar
Default Re: LT5 valve guide failures
Yikes- that is scary!
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 11-05-2019   #3
Graham,
Any sense on the cause of failure? Are these OEM?
Old 11-06-2019   #4
grahambehan
Graham,
Valve guides are stock. From the uneven tool marks on the end of the guides, they were over stressed whilst being knocked back to perform the port work then knocked back into position. After that it was just a matter of time.
Graham
Old 11-06-2019   #5
Thx Graham. Any outward signs, ie oil burning, spark plug coloring, indicative of a problem here?
Old 11-06-2019   #6
grahambehan
No comments from the owner re that, although it has heavy carbon deposits. The actual reason for taking it apart was, no compression on cyl 7 due to the parts of valve guide passing through the cylinder.
Graham
Old 11-06-2019   #7
Jagdpanzer
Jagdpanzer's Avatar
Graham,
Do you have any experience with the VG 19292/00 aluminum bronze valve guide SI International makes for the LT5 cylinder head?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 11-06-2019   #8
grahambehan
Graham,
No sir, not in LT5 applications, but al bronze should be fine.
Graham
Old 11-12-2019   #9
rkreigh
on the old LSV we saw 3 guides that had noticeable wear after 106k. The other thing was the idler shaft for cam chains.
That was a bit of a surprise. Thanks Phil for all your help on this!
