Old 10-18-2019   #1
Default Endangered Species Parts list
I saw that Pete had posted for sale 2 Secondary Injector Relays. That got me to thinking about some other “unique” parts and more specifically the LT-5 has that do not appear to have substitutes in the Corvette world.
These are the kind of parts that our ZRs cannot run without. IOW, the motor is a boat anchor.
Maybe some of u would like to add to this list if u can think of anything.
As a start:
1. Ignition Control Module
2. Ignition Coil Housing
3. Secondary Injector Relay
4. Piston Rings
Feel free to suggest other parts.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 10-19-2019   #2
Default Re: Endangered Species Parts list
ECM
Oil temperature sensor 90-91
Not motor related
Rear bumper
Rear quarter panels
Doors
Body trim
Old 10-20-2019   #3
billschroeder5842
billschroeder5842's Avatar
Thermostat housing
Interior console trim with "power" switch
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 10-20-2019   #4
aafc
aafc's Avatar
As for interior console trim with "POWER KEY" you can use a regular console
trim from 90-91 just cut out a hole to fit the "POWER KEY" like i did when i added the automatic trans back in 2004.
Attachment 10640
aafc is offline   Reply With Quote
Old 10-20-2019   #5
tccrab
tccrab's Avatar
ABS relay (1990 model year)
Rear Bumper Facia (any year)
Rear Bumper Side Mouldings (any year)
Rear License Plate Surround (any year)
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 10-20-2019   #6
These are also common to all C4
Original black steel Clutch Master cylinder
Clutch neutral safety switch
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 10-20-2019   #7
Young1
Young1's Avatar
Camshaft position sensor
Steve Young
Second Owner
SOLD
SOLD
Old 10-21-2019   #8
spork2367
As a start:
4. Piston Rings
Piston rings is arguable as others have had luck with the total seal replacements.
ECM
Arguable as the megasquirt unit is pretty much plug and play (with minor tuning).
Originally Posted by billschroeder5842 View Post
Thermostat housing
Why would you ever need a replacement thermostat housing?
'Crabs
Rear ZR1 specific aftermarket bumper moldings have been available on Ebay for about a year.
There is a workable replacement for this, just not OEM.
Old 10-21-2019   #9
Total Seal does not have rings compatible w our motors. Have not made them since early 2010’s. There are no rings they know of that would fit our ring grooves.
Sorry but MS is not plug and play, not to mention u lose CCM comms.
Old 10-21-2019   #10
spork2367
You didn’t say “exact OEM part.” You said “substitute.” There are substitutes the car will run with. You don’t need a fuel mileage calculator to drive the car. If you meant OEM equivalent replacement, then you would be correct.
Total seal still has the rings in their catalog and would make them if you wanted to pony up.
I have a MS on my 1990 so I’m aware of its plug and play-ability as well as its limitations.
I work in an industry where we support 50+ year old legacy engines, so I live this every day. Hell, I deal with 4-5 vendors that were suppliers for OEM LT5 parts.
