Old 10-18-2019   #1
ZuggZR1
ZuggZR1's Avatar
Default 90 ZR1 power Antenna stuck up
My antenna went up yesterday like normal but will not go down now. I tried pushing down but not sure how much force I should use. Any suggestions?
ZuggZR1 is offline   Reply With Quote
Old 10-18-2019   #2
Default Re: 90 ZR1 power Antenna stuck up
Could be the ribbon is striped or broken or motor bad. Do you hear the motor running? If its the ribbon it can be replaced.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 10-18-2019   #3
32valvesftw
I was able to push mine down but I had to time it with when the antenna motor was operating
Old 10-18-2019   #4
lfalzarano
https://www.zip-corvette.com/78-82-8...le-w-o-cb.html
Old 10-18-2019   #5
https://www.zip-corvette.com/88-92-a...air-cable.html
https://www.corvettecentral.com/c4-8...air-kit-164042
Steve
1990 Red/Red #1473
