Old 10-02-2019   #1
ZR11974
Default 1990 key chain
Good afternoon, everyone. I recently purchased my first 1990 ZR-1, and it is a one owner. He had almost everything that came with the car. He even said the keychain the keys were on was the original key ring, too. Apparently it used to have a Corvette emblem inside the metal housing, but he said it fell off years ago. I've attached a picture and since I can't find anything like it on the internet I thought I'd put it out to the specialists, here.
Anyone recognize this keyring? And, know where I can get an original replacement?
Thanks, and take care.
ZR11974 is offline   Reply With Quote
Old 10-02-2019   #2
91vettezr1
91vettezr1's Avatar
Default Re: 1990 key chain
original 90-91 keychain were brass with zr-1 cast in the front. they are on ebay for around $75
91vettezr1 is offline   Reply With Quote
Old 10-02-2019   #3
ZR11974
91vettezr1,
Thank you so much for the input. The brass keychain that has the ZR-1 logo on it I still have in the pizza box. I don't want to use that one, as I want to keep it perfect. The one I have is in the picture.
Thanks.
Old 10-03-2019   #4
That is simply a generic after market key ring
Old 10-03-2019   #5
ZR11974
Goldcylon,
Okay. That makes sense. Then I bet I should start searching for Chevy keyrings. Thank you so much for the information.
I'll start a new search!
Respectfully,
ZR11974
Old 10-03-2019   #6
Brass ZR-1 Corvette Key Ring
This is aftermarket identical to original except Rings are a bit larger than original.......like 91vettezr1 suggests
Old 10-04-2019   #7
ZR11974
That's great, thank you. I appreciate the support!
Tags
1990, keychain
