Old 09-14-2019   #1
Jetjock
Jetjock's Avatar
Default Light chime
I’m reading the NCRS judging manual and testing the lights. There is supposed to be a chime when the lights are on and the ignition switch is either off or lock. I did this and no chime. I don’t know if this is tied into the door jamb switch or not since I’m having problems with it. The other thing is when the key is in the ignition and the door is open. Basically the chime isn’t working. I’m checking the fuses to see if one of them is blown. Otherwise, any ideas?
Roy L. Carman
If I feel the need for speed,
I just think about flying the B-777.
1989 Dk Blue Coupe lost in divorce
1991 Black Coupe SOLD
1992 Black ZR-1 #423 SOLD!
1993 Ruby Red 40th Anniversary ZR-1 #334
1995 Black ZR-1 taken by ex-wife
2002 Pewter Coupe no idea where it is
2003 50th Anniversary Corvette #No idea what number SOLD!
ZR-1 Net Registry #516
Grand Sport Lifetime Member
NCM Lifetime #1468
ZR-1 Net Registry Board Secretary
Jetjock is offline   Reply With Quote
Old 09-14-2019   #2
Default Re: Light chime
First confirm courtesy lights are on with door open.. if yes, turn on headlights? Does the chime sound? If not, replace the chime. Dash pad has to come off for chime replacement
Old 09-14-2019   #3
Mystic ZR-1
Mystic ZR-1's Avatar
Does it work with the key out?
Actually, it‘s not a lights on reminder.
It‘s a stall warning!
Get that nose down...
Old 09-14-2019   #4
TX '90 ZR1
TX '90 ZR1's Avatar
😀[/QUOTE]
Or Up! It's an angle of attack thing.
Kenny
1990 #442
Old 09-14-2019   #5
Jetjock
Jetjock's Avatar
Amateurs. I’m surrounded by amateurs.
Roy L. Carman
NCM Lifetime #1468
Old 09-14-2019   #6
LOL.. also you can remove the switch without removing the panel. You will need a longer screw to hold the plate in place in the door.. that is how I remove those switches now if needed
Old 09-14-2019   #7
Mystic ZR-1
Old 09-15-2019   #8
BigJohn
BigJohn's Avatar
Well I had a no start problem, until I discovered I had the wrong key.
So much for my key box theory.
Old 09-15-2019   #9
Jetjock
Jetjock's Avatar
Actually, I don’t have to replace the pad. Gordon told me a little trick that they did at the plant. They cut a hole in the area behind the DIC to get access because pulling the pad was such a hassle. I have a hole cut to get to the LTPWS module. The tone generator is next to it.
Roy L. Carman
NCM Lifetime #1468
Old 09-15-2019   #10
Jetjock
Jetjock's Avatar
[/QUOTE]
The stall warning is actually quite violent and accompanied by the stick shaker. You would pee in your pants if you went through it. 😂
Roy L. Carman
NCM Lifetime #1468
