09-11-2019 | #1 |
A/C Cooling issues
High guys I'm new here just got my car 2 weeks ago, it seems that my AC unit is malfunctioning, it blows out hot air even though the compressor is running and it shows good on the low side pressure, anyone have any experience with this, I am by no means an AC expert but options for people to work on this are limited, unless you all think this something any garage should be able to handle.
Dave
Dave 1993 Ruby Red 40th Anniversary ZR-1 #127 2011 Black ZR1 #132 [SIGPIC][/SIGPIC] |
09-11-2019 | #2 |
Re: A/C Cooling issues
Any large GM dealer in your can handle the diagnostic and repair. just had mine fixed a month or so. AC clutch was the culprit.
09-11-2019 | #3 |
Dave congrats on your new car- I hope you love your ZR1 as much as the rest of us do!
Lou is correct; take your AC issue to a competent dealer for a solid, quick (and yes, expensive) fix. AC is tricky under any circumstance. Now.... Where are the pictures???
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker |
09-11-2019 | #4 | |
If you are not inclined...take it to an AC type shop. I assume a 93' is R12? My 95' is R134. How long has the AC not been working by previous owner? Maybe just a very slow leak and needs a can of R12 or R134 for another 10 years
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-11-2019 at 09:22 PM. |
09-12-2019 | #5 | |
Thank you all for the info, I will take it over to a local AC shop. IMG_0801.jpg Sent from my iPhone using ZR-1 Net Registry
