Old 09-06-2019   #1
Default A/C compressor is screaming........
It’s got to be a bearing,anybody have any problems like this?
Old 09-06-2019   #2
Default Re: A/C compressor is screaming........
all the time meaning AC on or off?
Old 09-06-2019   #3
A/C on which sounds like the clutch but I’ve never messed with one so I’m not sure.
Old 09-06-2019   #4
could be the clutch, could be a bearing.. while screaming does it actually work to cool the car?
Old 09-06-2019   #5
If noise only occurs when AC is turned on, probably the clutch worn out & metal to metal.
Old 09-20-2019   #6
jss06c6
Mine squeals when I haven't driven it in a while. Has a new bearing in a new compressor, so only thing it can be is the clutch. It goes away after a minute or two of driving.
Sent from my SM-G950U using ZR-1 Net Registry mobile app
Old 09-27-2019   #7
onetinsoldier
don't drive it , mine did that and before I got home I , it cut through the snout of the compressor and couldn't be repaired !
onetinsoldier is offline   Reply With Quote
