Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 NCRS for ZR-1s
Old 09-02-2019   #1
SitkaSam
SitkaSam's Avatar
Default Code 12
I have been going through various postings on the Forum stating code 12 means everything is normal.
However reading the NCRS Operations Manual & PV Test Guide, code 12 States
"Distributor Pulses"
Has anybody gotten the same code, and what does it mean?
Would this cause a Fail?
Thanks
1990 ZR-1
1993 ZR-1
2011 ZR-1
1958 Corvette
1947 Cadillac
Denali XL Conversion~ Duramax/Allison
SitkaSam is offline   Reply With Quote
Old 09-03-2019   #2
Default Re: Code 12
Code 12 flashes at the start of reading MALF codes that have been set. If u put ECM into ALDL mode, and it only flashes 1 and then 2, there are no other codes and everything checks out.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 09-03-2019   #3
SitkaSam
SitkaSam's Avatar
Default Re: Code 12
Thank you so much! Now I understand, as NCRS publication had me worried.
1990 ZR-1
1993 ZR-1
2011 ZR-1
1958 Corvette
1947 Cadillac
