08-31-2019 | #1 |
Replacing the serpentine belt: Best way?
Took me 2-1/2 hours & a couple BandAids to remove and reinstall a new (AC Delco) belt today. Gawd! There must be an easier way/faster way to do it. Suggestions?
09-01-2019 | #2 |
Re: Replacing the serpentine belt: Best way?
Paul, I was able to use a 1/2" drive ratchet with a long handle and broken neck.
Put the drive in the tensioner, clocked it just right and hooked it behind something, I forget what it was. Took the tension off and held it in place. Made the job much easier. Last edited by efnfast; 09-01-2019 at 12:39 PM. |
09-01-2019 | #3 | |
Looking back, part of the problem was the way the new belt was packaged. It came folded in such a way as to make a Samurai (blacksmith) proud and wrapped tightly in a paper sleeve - the whole package would just about fit on palm of my open hand (ok, I have big hands?). When I first saw it, I said to myself, "Naw...That can't be the right belt!!" Can we say kinked?? Anyway... I got distracted and had to leave it and come back the next morning. Once the belt had a chance to relax (de-kink itself) AND I retracted the tensioner fully, it went on easy-peazy. It's amazing how sometimes when you "hit a wall" with a mechanical installation how leaving it and coming back with a fresh look and how easy then the task just comes together! Funny now, yes. But, I thought some of us DIY guys would see the humor in my little folly!
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 09-01-2019 at 08:50 AM. |
09-01-2019 | #4 |
My Method does not matter if belt is kinked and you do not have to use a lasso
Post 287 - Replacing the Serpentine Belt I replaced my Steel Water Pump Pulley with a Billet Aluminum Water Pump Pulley. The Billet Aluminum Water Pump Pulley does not have the ridge (larger diameter) on the front. Place New Serpentine Belt on all pulleys except the water pump pulley. Compress Belt Tensioner with hand so you can insert a stick of wood (1" x 2" x 24")..... or long handle 1/2" drive breaker bar to hold Belt Tensioner compressed. Slide smooth backside of Serpentine Belt on Billet Aluminum Water Pump Pulley (easy since it has no ridge on front edge of Billet Aluminum Water Pump Pulley). Remove stick of wood or 1/2" drive breaker bar. This applies to LT5s and L98s. Now I know why I got the Billet Aliuminum Water Pump Pulley LT5 Billet Aluminum Water Pump Pulley.....L98 Billet Aluminum Water Pump Pulley L98 with Air Pump Eliminated Note the Power Steering Pulley rides on smooth back side of Serpentine Belt on L98 Easy-Peazy
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-01-2019 at 11:51 PM. |
09-01-2019 | #5 |
I use a 1/2” drive breaker bar in the tensioner to pull it back, then slip a large flat blade screwdriver under belt and over alternator pulley.
09-01-2019 | #6 |
There is a belt out there that is IMPOSSIBLE to install,I went through this the first time I replaced it years ago,it’s almost as if it was mis labeled from the factory. I can’t remember which brand,maybe Goodyear or OEM GM. after fighting with this for too long,went and got a GATES belt and had it on the car in the time it takes to loop it around all the pulleys and release the tension. This reminds me,I need to change out that belt.
09-02-2019 | #7 |
I think the procedure in the manual was to install the belt over and behind the water pump pulley. After the belt is around all the other pulleys, you can pull the belt forward onto the water pump pulley while pulling back on the tensioner. This worked well when I removed and reinstalled the original belt.
Even with that procedure, some belts will not go on. I had a new belt with the exact same part number as the original belt that would not go on. I think the Goodyear belt went on easily without this procedure. |
09-02-2019 | #8 |
It all depends on the length of the belt. Been down that road. However shorter is better, but a bit harder to install.
H http://www.zr1.net/forum/showthread....erpentine+belt
09-02-2019 | #9 | |
09-02-2019 | #10 | |
THANKS 4 ALL THE RESPONSES!
