Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 NCRS for ZR-1s
Old 08-09-2019   #1
bowtiguy
Default Max deduction for A/C that does not blowing cold?
Any experts know what I can expect for a deduction total on the A/C that doesn't drop the recommended 20 degrees? I trusted my A/C guy a little too much and I don't have the time to address it prior to judging next weekend.
Little background on the car. Under 10K miles. all parts are factory installed. the only condition issue is a slightly rubbed aluminum crimp near the coolant crossover pipe. Blower motor, control center , all vents, heat work just fine.
bowtiguy is offline   Reply With Quote
Old 08-09-2019   #2
lfalzarano
Default Re: Max deduction for A/C that does not blow cold?
Take it in for the AC now. It’s only going to get hotter!
Old 08-09-2019   #3
bowtiguy
It will be fixed, but I'm not letting some ham fisted tech pull my plenum to get to the compressor after a full restoration. I'll weigh my options... stay with R12 or go to R134. I've got bent windows in the 68' C10 and good air in my H3 Alpha for now!
Old 08-09-2019   #4
lfalzarano
Have them change it out to R134a. There are no hoses, switches or compressor to change out.
My was fixed a few weeks ago. It was a clutch switch that had gone bad. The R134a cools just fine.
Old 08-09-2019   #5
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Flight Judging or Performance Verification?
PV = Fail
Flight Judging = 25 points ( if they catch it )
Marty
Old 08-10-2019   #6
bowtiguy
I WISH it was that easy on my car. wont hold a vac test. spent 98% of its life in dry Colorado so I suspect seals -everywhere.
PV = Fail
Marty
Flight Judging. 25 points is minimal in the overall picture. The repair is not doable before I leave on the 16th. Maybe I'll get the flight judging completed first, install new parts..then go for the PV.
R12 compressor runs when jumped at the switch. A forum member recommended rebuilding it while my plenum was off over the winter, but we just suspected bad schrader valves. The R12 compressor rebuild kits are cheap and would allow me to keep all the date coded factory parts VS. putting 94-95 parts in and making it functional. that is "IF" the factory line crimps are still holding....my oil cooler lines sure didnt.
Even though you cant read the part number/ date code of a 91 compressor ( its on the bottom) How much of a points deduction comes with putting 94-95 134a parts into a 91 car?
WHY am I going down this rabbit hole! I should have put my Port and polished top end form my other motor on the car over the winter along with my factory A-molds, period correct modified Borla exhaust & short shifter and been driving it all summer!!!
Old 08-10-2019   #7
lfalzarano
Default Re: Max deduction for A/C that does not blowing cold?
The 94-95 AC parts are metric and 90-93 are US customary measures.
Old 08-10-2019   #8
Joelbbvette
Joelbbvette's Avatar
Flight judging is 25 points for operations but they only feel for cold. Since the system is tested with fan speeds, Defrost, heat, etc. you should not see a total fail anyway. Again for PV, don't bother it is a total failure. Good luck with your flight judging and you should do fine. Let us know how it ends up.
Joel
Tampa/Rockledge, FL
Present Collection
1969 350/300 AC Convertible
1972 454 Coupe 2nd Owner
1988 KOH EX5006 - ZR-1 Prototype
1990 ZR-1 #277 NCRS Dave McLellan Award 2019
1994 Copper Convertible NCRS Dave Hill Award 2012
2001 Z06 122k miles
Joelbbvette is offline   Reply With Quote
Old 08-10-2019   #9
bowtiguy
I gathered that from subfixer's thread...
http://www.zr1.net/forum/showthread.php?t=30748
At this point it would be an "all in" proposition with everything being never 134 components if I couldnt get the system to hold a vac after rebuilding the R12 compressor and installing new gaskets/o-rings everywhere. I tend to through more $$$ at repairs and fix everything at once.
thanks, pretty clear it has to be 100% to pass the performance verification. More importantly, it gets HOT here and with all the californians and texans moving to Colorado, A/C is a must for happy cruising in traffic ...even in a "dry" heat.
Old 08-12-2019   #10
dredgeguy
dredgeguy's Avatar
My clutch switch is acting up. Purchased a new one off ebay but not correct. Where did you get yours?
Thanks
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
