Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 NCRS Topics
Old 07-23-2019   #1
musuraca
musuraca's Avatar
Default 10052168 ZR1 Rubber Fuel Line Clip/Spacer
I’m looking for Part #10052168 for a 94 NCRS Top Flight ZR1. This is a molded rubber space that holds the two braided fuel lines near the plenum. Attached is a picture.
Please let me know if you have this one, or one similar.
Thanks in advance,
Joe
musuraca is offline   Reply With Quote
Old 07-23-2019   #2
lfalzarano
Default Re: 10052168 ZR1 Rubber Fuel Line Clip/Spacer
You should be able to make one. The hard part is locating that style zip tie!
Old 07-23-2019   #3
musuraca
musuraca's Avatar
Lou,
I'll probably end up making one. Jerry's Gaskets has the perforated zip tie.
Thanks,
Joe
