Old 07-22-2019   #1
vermatrix
Default Switching out Seats
So I am going to be aquiring my first ZR1, probaly a 1990-1992 or so with higher miles due to my 20K or less budget.
Problem is, I am a BIG guy, I need alot of hip room. Those sport seats on the 90-92 wont do. But I have sat in the 95-06 styles and plenty of room there.
So my question is, whats the best way to switch those out? Will the Cusions and Covers from the wider bolstered 96 seat fit on the 90-92 seat backs?
Thanks
vermatrix is offline   Reply With Quote
Old 07-22-2019   #2
EvanZR1
EvanZR1's Avatar
Default Re: Switching out Seats
Not positive, but pretty sure you'll have to change the entire seat. You'll need to rewire the connector, either on the car side or seat side (or just make entirely new connectors on both sides). The seats themselves will physically fit and mount up just fine. For that matter, I've even seen people do C6 seats in the C4 with minor fab work on the seat brackets.
EvanZR1 is offline   Reply With Quote
Old 07-22-2019   #3
94 or 95 sport seats will be your best option. Or, like me, installed 95 base seats (and love them!). I had to give up the lumbar adjustment, but I never missed it even on long trips!
Jason @ Vette2Vette.com is where I got my seats.
Old 07-22-2019   #4
vermatrix
Did you just replace the seat foam and cover? or did you have to replace the entire seat assembly also?
what I am looking for is how is it done, or where can I go to get it done.
Thanks
Old 07-22-2019   #5
Demps
Demps's Avatar
Or just buy a ‘94 and you have it all.
Ted
Old 07-23-2019   #6
Thanks
Seat cushion comes right off
4 bolts hold the seat to the track.
Disconnect the wire harness and pull the old seat out. Couple minutes apiece to swap seats. EASY PLEASY!
Old 07-23-2019   #7
To go from the 90-93 to 94-95 seats you need to replace the frame as well. Looks Paul said remove bottom cushion and unbolt the current seat from the track and install the 94-later seat in its place.
If you want to keep the sport function with newer seats there is a bit more involved
Old 07-23-2019   #8
EvanZR1
EvanZR1's Avatar
I've never used the lumbar adjustment on any of the C4s I've owned. The C4 seats were good enough that you don't really need it.
Old 07-23-2019   #9
vermatrix
Do the 94-96 seat cusions fit in the 1991 seat box? If I took out the sport seats in the 1991 and replaced them with the 1994-1996 standard seats, would that be a problem for the electronics? I would not need the sport seat functions, I think the normal functions from the car would be fine?
Old 07-24-2019   #10
Again... if all you want is standard seats and (like me) you don't care about the lumbar bladder or bolster except to NOT have them cutting off circulation in your legs (I'm 6 foot, 240lbs), you're gonna love the standard 95 seats.
Believe me, remove the seat cushion to access the 4 bolt on the track. Remove them and disconnect the harness, and lift out the sport seat and replace them with the std seats and reinsert the 4 bolts holding the seat frame to the track. Install the bottom cushion to complete the swap and begin enjoying your std seats. (One of the best mods I've done on my 90 and my wife's 91 ZR-1s!
