07-08-2019 | #1 |
Need your assistance
I always have a trickle charge on the battery and this morning, I tried to start the car. There were no lights on and the car was dead. Assuming I had a bad battery, I jump started the car. It idled for a minute or so and died. I jump started a second time and it started right up. I ran it in the driveway until all the temperatures were normal and the parked it.
There was a rapid ticking noise coming from underneath the passenger side glove box. I tried to restart the car but everything was electrical dead and I couldn’t restart the car, but the rapid ticking still continues with the car being dead. Side notes, I was planning on getting the AC recharged, but on the second restart above it started blowing cold air. Secondly, the low tire pressure light came on and the car had not been moved. Any ideas as what could be ticking while all other electrical parts of the car are dead? Sent from my iPhone using ZR-1 Net Registry
07-08-2019 | #2 | |
Re: Need your assistance
You didn't say how old your battery is, but it does sound to me like a possible bad battery or bad battery connections. Bad batteries or low voltage situations induce quite a number of symptoms on C4 ZR-1s, like chattering relays, clicking solenoid, various idiot lights, etc. So that is the first place I would look. Check the connections for corrosion and get the battery load tested. Any auto parts store can do that for you. In the connections department, the ground connection at the rear of the engine often gets corroded but that is a bit harder to get at. I once got a brand new battery for a '67 Austin Healey and the car wouldn't start. I went through every possible culprit including replacing the starter, until I finally just by luck decided to jump the car with my other car, and it started right up. Turns out the new battery had a bad cell in it. Oh well. --Bob
07-08-2019 | #3 |
The battery is maybe 2 1/2 to 3 at the max, but it could be a bad cell. I’ll check for connections first and thanks for the guidance.
07-08-2019 | #4 |
07-08-2019 | #5 |
Battery or connections without a doubt.
First, have it load tested. Then check all of the connections with a wrench for tightness. (or the other way around) The earlier response on clicking noises was spot on. Anything less than full voltage will cause that to happen. Nothing wrong with the top of the line Delco with 36-42 month free replacement and it looks close to stock and under $140.00 Marty |
07-08-2019 | #6 |
You guys are the best and spot on. Replaced the battery and everything worked as normal including the AC not working and the false low tire pressure warning.
Thanks to everyone for your help. Sent from my iPhone using ZR-1 Net Registry
07-08-2019 | #7 |
Good for you- the easiest fixes are the best!
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker |
07-09-2019 | #8 | |
What model is the AC Delco? I was only able to buy AC Delco model PS75 with 650 CCA. Sent from my iPhone using ZR-1 Net Registry
07-09-2019 | #9 |
Delco 75VPG (professional gold)
700 CCA for 95 minutes 42 month free replacement side terminals only; looks close to original Although you will be fine with 650. Marty |
07-09-2019 | #10 |
Glad to hear it was an easy resolution of the problem. --Bob
