07-05-2019 | #1 |
Can't get into gear...
I've been noticing that getting into gear from a stop has been difficult. It got worse quickly. Now I can't hardly get the shifter into gear and also noticing the clutch is catching almost instantly when letting it out. What is happening??
07-05-2019 | #2 |
Re: Can't get into gear...
I had a similar issue and it turned out that my clutch fluid was very low. I filled the reservoir and it was like I installed a new clutch. Good luck.
07-05-2019 | #3 |
Also check the fork/Pivot ball .....
07-05-2019 | #4 | |
07-05-2019 | #5 |
under the computer on the driver side firewall
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
07-05-2019 | #6 |
Yes, it’s on the driver’s side, close to the firewall and under the computer.
07-06-2019 | #7 | |
07-06-2019 | #8 |
If...when you do remove the cap, you or your mechanic should bleed the clutch MASTER and SLAVE cylinders first. Then keep a close eye on the level, looking for signs of leakage.
Good luck!
07-06-2019 | #9 |
07-06-2019 | #10 |
I also had to use Channel lock pliers the first time, just wrap the cap with a rag. When refilling keep the level below the full mark or when you insert the black cup it will overflow.
