06-27-2019 | #1 |
Another What Oil do u use thread
Been looking for oil to replace the CASTROL GTX I had been using for a number of years. It is a conventional so wanting a synthetic.
Well, I found MOBIL 1 15W-50. Here are the specs which look like it contains adequate levels of ZDDP. Has anyone else discovered and been using it?
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 03-08-2024 at 02:09 PM. |
06-28-2019 | #2 |
Re: Another What Oil do u use thread
In 2014, after an engine rebuild, my oil pressure was unusually and uncomfortably low - 15 psi or so. I used Mobil 1 15W-50 just to increase the low rpm pressure 'cause it was the only thing I could do. It turned out to be a crankshaft oil galley plug that popped out.
After years of using Mobil1 and Mobil 1 High Mileage, I gave up a couple of months ago and went to Amsoil Z-Rod 10W-30 over the same concern - ZDDP. |
06-28-2019 | #3 |
Amsoil may be your solution. At one time I used M1 high mileage 10W40 that had the higher ZDDP but Mobil "quietly" changed the amount of ZDDP to a lower level. Click HERE for the current M1 oil specs. I have spec sheets from 2011 & 2014 showing that M1 high mileage 10W30 & 10W40 with a phosphorus level of 1000 and zinc level of 1100. Those levels were reduced some time after 2014 but, without access to later spec sheets, I'm not certain when that happened.
06-28-2019 | #4 |
Gunny,
Here’s the link to Mobil product specs on oils. You’ll note that the 15W-50 specifically mentions flat tappets and that the zinc content is within the acceptable range for our motors unlike Mobil 1 High Mileage 10W-40 which I have been using more recently. The 15W-50 can be had at Walmart, as an example, for $22/5qts. I am changing to this for other reasons in addition to the ZDDP insufficiency. You’ll note that this .pdf was published just this month, June 2019. https://mobiloil.com/~/media/amer/us...pecs-guide.pdf Same link.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 06-28-2019 at 08:35 AM. |
06-28-2019 | #5 |
There is a thread with literally ALL this information already in it...
http://www.zr1.net/forum/showthread.php?t=30261 15W-50 is considered by most to be a little on the heavy side for a stock LT-5, but I wouldn't be super worried unless you were running it in low temps. |
06-28-2019 | #6 |
Dom, I also did the same research you did and came to the Mobile 1 15w50 as a possible solution. And, Walmart does carry it regularly, but they also sell it online with free shipping. 5 qts for $23 is pretty darn cheap, but that was not part of the equation when I decided to change.
I have been using the Mobile 1 15w50 for 3 years now without issue. But I do not drive in cold weather at all.
91-#1935 Black/black & gray, Haibeck 500 Cams by Pete |
06-28-2019 | #7 | |
06-28-2019 | #8 | |
Good to know Dan.
06-28-2019 | #9 | |
In the end, i decided it simply was not worth the risk and started buying Amsoil online. |
06-28-2019 | #10 |
I decided not to cheap out on my Z and also use Amsoil. Stick with Marc and not your Piggy Bank!
