Old 06-26-2019   #1
Jagdpanzer
Jagdpanzer's Avatar
Default DIY Fuel Injector Testor
Here are photos of a home made fuel injector test rig I set up to check out a set of larger injectors I will be installing. They had been setting on the shelf for a while and I wanted to make sure they were good to go. Used a spare fuel rail I had laying around and my HM engine pre-oiler for the pressurized fuel supply source. Fired the injectors with this nifty tester I found on Amazon for $32. All injectors tested fine.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
