Old 06-22-2019   #1
BlackZR1
BlackZR1's Avatar
Default AC CV913C / 25098197 PCV VALVE
In case anyone needs these, this guy has 6 available.
https://www.ebay.com/itm/GENUINE-AC-...53.m1438.l2649
These are the ones that are hard to find.
I just bought a couple. He accepted $6. each, Free shipping. They say AC Rochester on the valve as opposed to AC Delco like Jerry used to stock. They look identical to the AC Delco valves. I have no affiliation.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Full-time secondaries, 4.10 gears, C-beam plates, ported top end
BlackZR1 is offline   Reply With Quote
Old 06-23-2019   #2
spork2367
Default Re: AC CV913C / 25098197 PCV VALVE
They do not look like the AC Delco version.
File Type: jpeg 742CA8B3-8D19-44D6-BE3B-57A91660B567.jpeg (36.3 KB, 18 views)
Old 06-23-2019   #3
BlackZR1
BlackZR1's Avatar
The body has identical dimensions. The AC Delco (Right) neck is 0.4 mm longer.
The AC Rochester valve (Left) also seems to be cadmium plated? (the greenish/pinkish finish seen best on the end view) vs. the bright finish on the AC Delco.
Let me know if there is anything else you would like me to check.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Old 06-23-2019   #4
secondchance
Seems correct part numbers are CV913C and CV769C.
Can someone confirm?
eBay link takes me to CV727C.
Old 06-23-2019   #5
BlackZR1
BlackZR1's Avatar
Those are the numbers I have (at least for my 1990.)
Looks like the Ebay seller has sold the remaining 6
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Old 06-24-2019   #6
spork2367
That's what happened to me. The original auction ended 2 days ago.
I'm not sure they are that hard to find as the AC DELCO 19303069 is $2.66 on Rock Auto.
Old 06-26-2019   #7
Jagdpanzer
Jagdpanzer's Avatar
I have a few NOS AC CV913C PCV valves in the parts stash. Let me know if you need one.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 06-26-2019   #8
secondchance
While we are on the subject of PCV valve. When I had head gasket problem, blowing steam and oil vapor would make the inside of PCV valves sticky. I would spray the inside with fuel injector cleaner, close the end with my thumb and shake it until inside was free and repeat as needed.
Do you think thins type of cleaning could make PCV valves function as intended for a long time?
