Old 06-01-2019   #1
Subfixer
Subfixer's Avatar
Default Got lucky this morning...
Started up the car to go to a show and there was a strong smell of gas.
There was a big leak around the fuel pressure regulator.
Glad it didn't fail while I was on the highway this morning.
I had changed the injectors and all the fuel line O-rings last month and had no issues. Started smelling gas after I changed the original fuel filter a couple of weeks ago, but could not find a leak anywhere.
Just did a 200 mile run last weekend with no issues.
At least I know my plenum drain isn't clogged...…..
Another plenum pull tomorrow.
2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
Old 06-02-2019   #2
Default Re: Got lucky this morning...
Post 281 - The Improved LT5 Fuel Pressure Regulator
Old 06-02-2019   #3
I agree with dynomite.. I replaced mine this year, before it could break..
Old 06-02-2019   #4
Subfixer
Subfixer's Avatar
Found the source of the leak this morning. Half rolled o-ring at the fuel regulator on the pipe feeding the drivers side fuel rail.
I'm guessing that when I replaced the original 27 year old fuel filter, I was finally getting full fuel pressure to the fuel rails, which was enough to get by the improperly installed o-ring.
I'll be reinspecting all my work to avoid further problems.
Old 06-02-2019   #5
I recommend lubricating the o-rings with engine oil before assembly, to help avoid damage.
Old 06-03-2019   #6
Subfixer
Subfixer's Avatar
Used engine oil, just wasn't careful enough. I'll do better this time....
Old 06-04-2019   #7
Pardon me. I thought this was about something entirely different.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 06-05-2019   #8
No more oysters for you Frankie!
Old 06-05-2019   #9
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Very good!
Marty
Old 06-05-2019   #10
32valvZ
32valvZ's Avatar
what was the price on that if you dont mind my asking...
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
