06-01-2019 | #1 |
AC conversion
Since my AC system is empty of R12, I'm going to convert to R134a.
I've got a new compressor on order, but I need the rest of the required parts. Is there a list, or kit, somewhere that has everything else I'll need? Thanks, Paul
1992 ZR1 #442, 2 tops, White, White, Haibeck 415, 3.90 gear, Coilovers 2018 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black 2021 Audi Q3, 2.0T, 8 spd Tiptronic, Navarro Blue metallic, Pearl Beige |
06-01-2019 | #2 |
Re: AC conversion
You probably don't need a compressor, unless that s a known problem or the cause of your leak...most likely culprits are Schrader valve or bad hose. Any parts store has a good conversion kit (oil and connections). Expect about a 15% loss in cooling, but it still works great in Phoenix …. for about 20 years, so.....
06-01-2019 | #3 |
Re: AC conversion
That’s a matter of much debate. Years ago we simply got the R134 oriface tube and fresh PAG oil. Evacuated, then just charged it with R134. Worked fine, never had an is issue. Today they want you to change everything. At minimum I would change out the receiver dryer simply because of age. I’m sure you will hear other opinions.
H
06-01-2019 | #4 |
Re: AC conversion
I read some articles in some past HOB issues detailing the change.
Looks like I have some work ahead of me. Pulling the plenum anyway due to a fuel leak.
06-02-2019 | #5 |
Re: AC conversion
Did the 93-95 ZR-1 go to R134a when new?
If so, was there a different condenser? Thanks
06-02-2019 | #6 |
Re: AC conversion
Yes not sure on 93 but 94-95 were R134a.. different pieces in the system and the condenser was a parallel flow not the tube and fin used with R12
06-02-2019 | #7 |
Re: AC conversion
ok thanks. Since I need a new condenser, I'll get one for a 94-95 plus all the other stuff I need.
06-02-2019 | #8 |
Re: AC conversion
You will need everything to my knowledge as the fitting are different and I think the oil cooler may have to change to mount correctly to the new condenser
06-02-2019 | #9 |
Re: AC conversion
Hahaha.... if it's not one thing, it's another.... the joys of owning an old car.
06-02-2019 | #10 |
Re: AC conversion
1994 was the first year for all US automobiles to be mandated to have R-134a
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
